I understand the concern, but it's really been a non-issue. Blow the intake area off with compressed air, stuff rags/towels in the ports when the intake is off, and double-check that nothing gets dropped down them before you put it back on. FYI, from what I understand about the UR starter, it requires removing the exhaust manifold (not really DIYable in the field, or even in a auto parts store parking lot). The only starter I've ever had to beat on was on my 1972 C10...guess that's Delco vs. Denso electronics
I pulled my intake off again a couple years ago to address a knock sensor code (it was the cracked pigtail). I did the job outside, in my driveway, and had it done in about two hours. Basically a "field repair". This past fall I checked compression on the rig, and it's within spec on all 8 cylinders, despite 200K on the rig.
