Hiluxforever
Oem -25What offset are the steelies?
BMC long since done on my GX haha
Interesting.Oem -25
That's an inch difference in offset, the + 20 should intrude about 3/4" further front and rear, since pushing the wheel out increases the scrub radius. Keeping them tight also reduces leverage on suspension and steering components.Interesting.
Offset is the next part of this decision. If I'm going with a 17x8" wheel, the options are 20mm or -6mm. Just not sure which will have a higher likelihood of rubbing.
Right... I get the geometry, and that the 20mm offset wheel tucks better and likely fits with less of an issue (especially considering stock wheels are 25mm offset), just trying to figure out if the -6 is doable since 0mm is basically the aftermarket standard for Toyota IFS vehicles.That's an inch difference in offset, the + 20 should intrude about 3/4" further front and rear, since pushing the wheel out increases the scrub radius. Keeping them tight also reduces leverage on suspension and steering components.
Tinkerers Adventure covers it really well. I rewatched his older videos.
Committed to 0 or +20?You will have to move stuff around and if you are committed to that wheel offset, you will need a BMC, almost for sure. I just cleared the BMC with -12 7.5s
I had the same size tire in KO2 format with no issues of rubbing, albeit, I did have the BMC done. With zero offset on my wheels, and that size tire, there were never any rubbing issues, not till I mounted the 315's on which were about an inch larger in diameter a an inch or so wider. The width is where I get rubbing and that's only on lock-to-lock. I'm going back to the 285/75's when these wear out.The +20
I agree about having too negative an offset or fatty tires. I hate having mud slung all along the side of my rig, along with all the stone paint chips.I would consider negative offset on these rigs. Not only will you push the wheel out and hit more of the fenders but you'll throw mud/snow/rocks/water/salt down the side of your rig. IMO they look perfect with 0 offset wheels. I have maybe 1/2" of poke outside of the fenders with 285/70R17 tires and 17x8.5, 0-offset wheels. And I had to do a BMC and trim a bunch of stuff to get them to fit.
A +10 or +15 mm wheel would honestly be kind of nice for these rigs, but wouldn't look as good as the 0-offset wheels. The +20/25 mm wheels certainly tuck great, but IMO the rigs look drastically better with a little bit of poke.
Where the rubbing is happening matters. I had stock wheels with 265/70/R17's on my lifted (2 1/2"F, 2"R) 2007 4R. Had JBA HD UCAs which rubbed slightly. Nowhere as noisy as the front wheel well on the GX. Solutions are to change wheel size, width, offset, etc. I'll pass.What are folks running for UCAs. I am at the 1.75 setting on my 5100s and have rubbing issues.
