Reading various builds and the 45 gallon aux tank thread got me thinking back again on this topic. I'm curious what kind of curb weight some of the built rigs are weighing in at. I'm sure waaaay over GVWR. This is rarely talked about on these boards as we're generally focus'd with building up and adding gear. Almost never are we trading gear for something lighter.
As much as we're not a Lotus, I strongly believe Chapman's philosophy of "adding lightness", or tempering weight, certainly still applies. Because just about everything works better when lighter.
Weight is an interesting slippery slope. Consider armor. It's used to protect the structure from rock damage, and has to be at least some minimum robustness to put up with hits without too much deformation. Consider a lighter built one that is designed for a ~7000lb rig. Now that we build out the rest of the rig, it's closer to 8000lbs. Will that same rear bumper take a hit on behalf of a 8000lb rig? So we may need a heavier build Slee one, increasing the weight of the buildout. Then we pile in gear for an expedition and we're now at 9000lbs. Will that bumper take that hit? Even if it does, will the frame we're trying to protect handle it?
Same thing with carrying spare parts. CV axles? They are probably indestructible on a lighter overland setup. Now a 9000lb+ build with drawers and the full complement of gear and spare parts? Yeah, it's prob no longer bombproof at this load level.
On a more concrete point, looking at GAWR (gross axle weight rating). On my LX570 (is the LC the same?) it's:
Front: 3595lbs
Rear 4300lbs
That's a pretty generous 7895 lb capacity for a rig that's GVWR 7275 lbs.
It's just something to consider, to balance builds with weight in mind.
Front: 3595lbs
Rear 4300lbs
