Progress
After a couple of tough weeks, frustrating finds, and PIA resolutions. Today was a good day.
!)Fixed the leak behind the timing plate... (Grant - OEM Gasket
& a bit of aviation) NO LEAK. All re-assembled and turning good.
2)recieved new/original stock perch pins/bushings....And after a lot of grinding measuring, careful PIA step by step, but all assembled Front and Rear today... and when it looks right, fights right, it must be right... Love going back to stock no more confusion.
3)2.5 over stock on new shackles.. Looks awesome, I like the stance. Did not realize how much difference it would make... but wow. Looks good.
4)Installed a new clutch line... having a small arguement with that... I think I will win. It worked before, but now can't get fluid back into the line. Will try gravity in the morning and if not, will have to do it another way.... Not sure why I am not getting pressure. (NO pedal) All I did was change the line. OH well, Resolution tomorrow.
Driving that thing in previous years has been dangerous. Fellow Mud Member taught me about Castor Angle.... Never knew anyting about it?? Got some 4* shims and that should greatly help. Might need more Degree... but will start there and look for improvement, until I can get to a shop and have it properly measured. I have 4inch re-arched springs (20years ago) with new 2.5" over shackles. WIthout any corrective measures installed... LMAO:whoops:
I had no idea... Live / Learn
Got to do some small dis-assembly to get back under Tranny hump, AARGH.
Figure that is just par for the restoration. but then it will be back and running. Was not looking forward to all the work that was ahead..... only because all the work that was behind....
have settled in, gotten over, and am reeling in the satisfaction of accomplishing this task in my drive-way. I did not think I could do it.
Could not have done it without the help and support. SO want to give a thanks for all the help that came my way.... As always appreciated
Respect.
**Pics and maybe a video shortly to see the updates... Too damn tired tonight.
