CloudCity
LuxCruisers
This was my take-away as well. My earlier reply has a link to my post, but you may not need to replace yours if your screen isn;t clogged, just fill it up to the fill lines. I would be concerned where the fluid went however. Once confirmed filled to the proper level, drive it then check for leaks or dropped level. If leak is minor add AT-205 leak sealer, drive for a while, recheck.Your welcome. Make sure to double check the PS reservoir. I only had a glimpse of inside. But I saw what may be the screen (I should not be able to) and did not see a drip of fluid off the stick on cap. This may just have been video tricks of the eye and camera man not being a pro,,,LOL. But if it is that low, the vane pump is being damaged.
Finally, in the first video it did look like your fan was slightly off balance, that's another consideration if we are mistaken on the reservoir levels.
