For Sale Grand Rapids, MI 1996 Land Cruiser 80
Year
1996
  1. 80 Series
Grand Rapids, Michigan United States
Mileage
254000
Color
Black
Outside Link
https://www.facebook.com/marketplace/item/753292973256561/
Posting this for a friend, I will pass any comments or questions to him:
Selling my 96 80 Series Land Cruiser. Runs great, I just don’t use it enough.
Frame is solid and was coated with fluid film before last winter. The cab corners are starting to rust but no other rust besides that. The vehicle was in California most of its life.
Rear main seal is slowly leaking and will need to be replaced eventually
Has ~254,000 miles on it. Extensive work and maintenance was done by the previous owner, I can share the list. Has a 2” lift and OME steering stabilizer and shocks. I replaced the front seat leather and also purchased fender flares to be installed, which will be sold with the vehicle. Good tread left on the Falken Wildpeak tires. Please ask any questions! Asking 10k.
Here is a Dropbox LINK to more pics, including undercarriage.
Here’s a list of everything the previous owner did:
here is the list of everything that was done maintenance wise in the last 3 yrs.
-Replaced air filter
-Replaced engine bay strut hatches.
-Rebuilt the power steering pump.
-Replaced the power steering lines
- Replaced distributor cap, rotary switch, & all distributor O-rings
- Valve cover and spark plug reseal
- New Denso spark plugs & boots
- New throttle body gasket
- Replaced the gear oil in both diffs, and transfer case.
- Replaced all three wiper arms & blades
- Replaced the steering wheel main shaft seal
- New Aisin water pump
- New Aisin fan clutch
- New thermostat
- Oil pump cover gasket resealed
- Resealed oil pan #2
- Crank shaft seal replaced
- New OEM fan belts installed
- Coolant petcock valve installed on engine block
- Coolant system flushed and filled with Asian red.
- All coolant hoses and clamps replaced
- Heater control valve replaced
- Pesky heater hose bypassed
- Rear heater bypassed
- Carpet was power washed
- New Duralast alternator installed (OEM Denso rebuilt alternator included in sale)
- Vapor canister replaced
- OEM starter rebuilt
- Old Man Emu steering stabilizer installed
- CDL switch installed
- New dash, shifter and A/C control lights installed
- Fusible link replaced
‐ Rebuilt the cruise control
- Transmission pan filter and gasket replaced
- Driver side front seat gears replaced
- Brake system bled
- Full knuckle & birfield rebuild on the front axle
- New wheel stubs on front driver and passenger wheel hubs.
- Front rotors resurfaced
- New front brake pads
- EGR bypass kit installed
- Old Man Emu 2 inch suspension kit installed w/ 20mm spacers installed on the front
- Front pinion seal replaced
- OEM fuel filter installed
- OEM gas cap installed
- OEM gas door latch installed
- Steering wheel recovered with Lonckey leather steering wheel
- New front seat leather
