ok after my bought with death wobble soa 39.5 iroks checked the entire front over found no play kept playing with toe and checking all nuts and bolts and everything that i did find loose i tightened and the wobble got worse. wellthe guy fromthe shop just called and set caster was set at 1 3/4 degrees on both sides (glad i got them both the same but i was shooting for 4 guess i goofed somewhere) Now this is a reputable shop yet they have only dealt with lifted jeeps and chevys for the most part. And he is telling me that caster is good yet i still believe as i have read on here i need around 4. I also have the extended anti inversion shackles on the front and he is saying if i was to get rid of them i would have no problems and they have been on way before the dw started. The long and short is do i put shims in it to get me through to see if that is the problem and do i just ignore the shackles. Let me know what all you cruizer gurus say i just want to be able to drive on the road again
thanks
Bryon
thanks
Bryon
