Build Good Ole Rusty
Not good weather to lay under the truck looking at clutch lines
You need to make three.. Yours, one for Chicago and one for me..
My wife is awesome, no one else I'd rather have help me bleed brakes or a clutch. She has the whole "Press" "Release" thing down.
The bad news is the clutch is still a little wonkey. I inspected the master, slave and all the lines, no leaks. Fluid level was good. Went ahead and bleed the systems, the fluid was dark but not black. I replaced the master and slave a few years ago, all new fluid when I did that.
So, if I pump the clutch a couple of times everything is fine. When the truck has been sitting it is difficult or impossible to get it in gear until I pump the clutch. I'm tempted to shot gun and replace the master and slave. Any merit to that approach?
That's what you should do. The Master is likely bad, the slave will soon follow if you replace the master. The slave is cheap. It seems like an easy choice.
it's better to replace it all at once, including the hose... that said, Toyota master cylinders and slave cylinder rebuild kits are so cheap and so easy to accomplish - that would be my first choice.... replace the hose, rebuild the cylinders... the rebuild kit is like $10.00 for both (all it is is a couple o-rings, a cup and a new boot)
I've never had any luck rebuilding a toyota master/slave cylinder. No matter brake or clutch.
I agree, no point in not doing both, did that last time when the master was leaking. I threw the old slave in my trail spares. Some guy was looking for a slave cylinder at Rubicon Springs one afternoon and I gave it to him. He was one happy guy.
Trail Karma is a wonderful thing.. :)
I've heard this many times over the years and have never bothered trying myself. I've know a few guys that carried re-build kits in their trail spares "just in case".
Just in case is an awesome idea. However, I've never had a problem starting the cruiser in gear and matching the engine RPM to shift. Clutch on = okay, clutch off = screwed.
That being said. I see no reason not to keep a rebuild kit on hand. It may work perfectly.
I gave a kid a Asin Hub one time on the Little Sluice bypass. It's amazing how sometimes the right guy with the right spare is in the right place at the right time.
I learned how to shift on an old international pick up that had no syncro, the clutch was only useful at a complete stop. Rest his soul my Dad was a patient man and taught my brother and I both how to shift with little or no help from a clutch. He drank a lot......:D
