- Joined
- Apr 14, 2004
- Threads
- 1,470
- Messages
- 36,726
- Location
- 818-953-9230
- Website
- www.marksoffroad.net
The holes in the passenger SIDE of the bellhousing, encroaching on the pocket for the starter, are the slave cylinder bracket holes. They are different to what I am used to seeing, so I'm not certain what they had in mind, other than to let you know that they were providing anchor points for SOMETHING. Could be for a direct mount of the slave, or for a bracket for the slave. Perhaps there is something in their instruction sheet about it.Those are the holes, thanks for clarifying. Is the third one on the side is for the clutch slave or something and meant to be the same way?
I don't need a shiny bellhousing, just want to make sure this is normal and will perform as advertised. Should I be concerned?
TIA all!
In my experience, the bellhousing offerings from Downey and AA always left something to be desired as far as optimizing slave cylinder location. And when you read so many threads on the forums about people having issues with adjusting their clutches, there is reason to be concerned. After a 'form follows function' talk with @Downey 25 years ago or so, I just decided that, rather than live with the compromise, I would mount a piece of angle iron to those holes and then mount the slave to the angle iron on the horizontal plane.
Once the slave is bled, it doesn't care if it's hung upside down. Freed from the vertical plane of the bellhousing, I could then move the slave at my discretion to both a point AND AN ANGLE that optimized its contact with the clutch fork. And that angle was never parallel to the powertrain, but always perpendicular to the fork. That is what I consider optimum.
