Hi All,
A while back I purchased a 12/78 40. It needs attention in several areas. Plan to start with rebuilding the existing 70's Chevy 305 and replace the 3spd TH250 transmission with an H42 next month. It has the OEM transfer case afaik. Research has led me to believe that for a street/fire road driven 40, the H42 is a good choice for a replacement transmission.
It had ATF in the transfer case and it was leaking like a stuck pig when I bought it. I removed the transfer case because it was whining pretty bad and wanted to see what was up in there. The TC input bearing had some rust, still rolling ok but that needed to be replaced. When I inspected the transmission output shaft I knew it was toast, it had about half of the material left on the output shaft. New bearing installed in TC and buttoned back up with gear oil and it's running ok. One day it's going to go boom and leave me stranded.
I could have the existing transmission rebuilt, but I really prefer stick in these. Now's the time to get it done, including the engine. I'm having a local shop rebuild the engine and I've got an H42 w/ 60 series shift plate coming from @65swb45. Still need to get the correct bell housing, flywheel, clutch, mounts. Probably new TC input gear, drive shafts, and a bunch other things. I want to be sure all this stuff lines up. Any help is much appreciated. Hoping to have the drivetrain work complete by February '18 then dive into body work/power steering.
Here's some pics
Transmission output shaft ... How'd this happen?
Engine placement
Here's some pics
Engine placement
