Planning a Vortec 350/4L60E conversion for my 82 FJ60 & see only stock Toyota transfer cases used - might it not be simpler to use the GM & modify the U-joint yokes on drive shafts?
So to get it to work with the 4L60E (6 bolt hex pattern for transfer case), you just use an adapter to create a 4 bolt pattern and maybe swap output shafts?
