Glow plug timer for a LN65 Hilux (1 Viewer)
Does anyone know where I can source a glow plug timer for a LN65 Hilux? I haven't been able to locate one.
Not sure where you are located, but in the unlikely event that Beno can’t help, try RADD Cruisers in British Columbia. They specialize in JDM parts and are in the process of getting set up as Amazon retailers so should be easy to deal with. They are very knowledgeable with Toyota diesels.
I could not source a matching or equivalent from anywhere. I ended up wiring in a switch.
It is also a good idea to change to post-glow capable Glow Plugs like those used in Toyota's Super Glow system.
For the 2L the Toyota part number is 19850-54090. Aftermarket alternatives are NGK Y-715R and Bosch GPT-223
Thank you all for the quick responses. I eventually found an OEM one through Amayama, but the price is pretty steep at $500. I'll be looking at your recommendation Jonathan since that seems like the best way to go.
