projectTuRD
Do I clean everything up, replace everything?
Yes, head gasket fail.X2 and drain the oil/water ASAP.. if you are going to sit on it fir a while I would fill it with used motor oil to stop corrosion while you figure it out. Head gasket fail?
It runs (ran) great, but slowly started to lose power slightly.I would plan on seeing if you can get a good compression test , pull pan off , check condition and clearance on rod and main bearings , then if needed , complete overhaul , does it run ?
I don’t think it was flooded, there’s no other evidence of it.What caused the obvious water issue, was it really a head gasket leak....looks more like it was submerged...or flooded.....with salt water?
Before you start trying to break loose the bolts, soak the heck out of them wit WD or whatever rust-buster you find.
Drain the oil/ water concoction, pull the head and replace the HG. Cleanup as you go. Add a fresh oil filter, oil & coolant. It’ll be fine.
FWIW: Whenever I’ve R&R’d heads, I’ve always drained and refilled fluids after a few miles to make sure I flush out unwanted garbage that may be floating around the systems.
Whoa!If I was gonna pull the head, I would just pull the long block. Then you can clean, inspect, repair, re seal.
Going back to the original post, for some reason I got the impression that the engine was already out and on a stand , ( I’m not sure why I assumed that )Whoa!
Pulling the engine is a bit more involved than popping the head off. I personally would not do this unless I suspected something much more significant than a head gasket issue.
Head is off, waiting on another scraper to show up tomorrow. Hoping to reassemble it this week and make it to the PMC swap meet in Petaluma on 7/10.Update?
Are you having the head magnafluxed?
Good luck ! I bet you will be fineNo. No one local can do it, just going to clean it up and drop it back on.
