Learn from my mistakes folks. I ordered the 15 series thinking compatibility with frontrunner accessories and such and the bar is too thick and touching the roof
. It doesn't work. So now I am stuck with a bunch of series 15. Ugh!!!
Learn from my mistakes folks. I ordered the 15 series thinking compatibility with frontrunner accessories and such and the bar is too thick and touching the roof. It doesn't work. So now I am stuck with a bunch of series 15. Ugh!!!
couple of thoughts..
1) I reused my inside tab plates to mount my 8020 bars too. the thread is m6 1.00 and a 20mm button head from Lowes fits fine. I did not reuse the knobs.. you could as above though.
2) 8020.net sells M6 tapped blocks which are 10x15mm - they should slide into the factory rails like the OEM ones, using the economy T-nuts is a pain on the OEM rack since you have to orient them vertically..
What brackets did you use for the light bar. I have been looking for a set for my setup. ThanksThanks to those who set the way for this. I recently got 6 bars although I did a single wide for the front to mount the arb baserack slim light bar. I've also mounted a swivel ram mount to a weboost antenna.
View attachment 3617363View attachment 3617364View attachment 3617365View attachment 3617366
Used t track bolts and these brackets came with the arb light bar, I picked it because of how thin it is (just over 1 inch tall). You wouldn’t notice it’s there and it clears the roof. There brackets have a curve, so that’s why I had to go with a track that was only one track wide vs the rest being two.What brackets did you use for the light bar. I have been looking for a set for my setup. Thanks
