I believe Slee's website has it backwards. My measurements (after 8K miles) of my 850/860 springs with just sliders and a full tank of fuel are:
DF-22.5"
PF-22.25"
DR-23
PR-23
I'd imagine if i was sitting in drivers seat then it'd be perfectly level left to right. Mine don't have A or B. Never did even new. I replaced the longer spring (driver) with the longer OME spring. Seems pretty easy to do it correctly. Stock springs are different lengths. Match them up and all done!
Yes, try to find the tags to see if they are on the correct side.Ok, I thought with the interior I was done with projects. Then walking up to the rear last night my wife points out the car is leaning with the driver's lower than the passengers side.... Here are measurements from the underside of the wheel flare through the hub to a level concrete surface:
LF 34" RF 35" 1" difference
LR 34.75" RR 36" 1.25" difference
Car is LHD, US spec.
Iron Pig put an ARB front bumper on in 2014. They did front springs, steering dampener, all four shocks. I am uncertain about rear springs and cannot find the invoice.
I did not see tags on the rear springs this morning, I think I may have seen tags on the front.
So, am I correct that my first step is to see where my front A and B are located and hope the A is in the wrong place?
Should I assume the rear are in the wrong sides and just swap them?
Do I ignore the listing? Mentally that is a challenge.
I just watched the OTRtAMM series on tge front and rear suspension. I will need to find a buddy for this.some OME rear springs also cater for having a swing away wheel carrier on the back as well, in those cases the 'stronger' spring goes on the carrier side, my 863's are configured that way for a Kaymar carrier on the rear LHS (Aus passenger side)
As Bilt4me said, you may need to swap them around
Ok, so my starting point does not include new parts (necessarily). That is good.Pull the springs out then put them next to each other the tall one should be on the drivers side LHD rig
Everything else is a guess
If the tall one was on the drivers side you can decide what to do from there.
Simple![]()
