FZJ105 and other newer Toyota parts for FZJ80
HDJdreams
Rocky Mountains
Overview:
The FZJ105 is essentially the same chassis as the FZJ80 with wider body mounts for the 100 series body.
Over the years details have trickled out on Mud about various changes made to the FZJ105 compared to the FZJ80. This thread is intended to be a FAQ link or Stick that lists as many as possible, the next 7 posts will be summaries of the respective systems. I will edit/update them as information comes in.
FZJ105 and other newer Toyota parts that are upgrades and can bolted on the FZJ80 will be noted (I.e. steering sector shaft). :hmm:
I also want to note aftermarket upgrades that are directly analogous to upgraded FZJ105 parts that don’t fit on the FZJ80. (I.e. the FZJ105 has M10 hub studs where the FZJ80 has M8 studs. The M10 cone washers hang out past the FZJ80 hub, so those won’t work but Front Range Off Road sells stronger M8 ARP studs, so they get an honorable mention).
Aftermarket parts that allow for the use of newer upgraded Toyota parts will be note too. (I.e. upgraded knuckles that allow for the use of larger current model 4Runner brakes on an FZJ80 or and adapter kit to bolt a A750F 5 speed to 1FZ would get mentioned.)
Enjoy!:popcorn:
Front Axle/Steering/Brakes/Suspension
FZJ105 has a stronger axle housing, a direct fit for FZJ80 (verify)(PN?)
FZJ105 spindle (PN?)has a roller bearings where the FZJ80 has a bronze bushing. (Fit?)
FZJ105 hub is 110 mm in diameter with 5 lugs, uses M10 hub studs, and 10 mm dowels. FZJ80 and other 6 lug Toyota hubs are 106 mm in diameter, with M8 studs and 7 mm dowels. 10 mm dowels could be retrofitted with high precision drilling. While the M10 studs might fit in the FZJ80 hub, the M10 cone washers hang out past the hub flange.
Rear Axle/Brakes/Suspension
Rear hub has the same differences noted on front hub.
The rear axle ring and pinion was changed in 98. Though the ring gear was listed the same diameter as the older design at 9.5”, it has a wider tooth face than the older design. 98+ had a 29 spline pinion where the older one had 27 spline. Later on the newer gears got a 32 spline pinion. (Year?)
The carrier for the 98+ gears uses 32 spline axle shafts, 97 older use 30 spline.
It sounds like the 98+ gears and carrier CAN fit in an older 3rd member. Custom 32 spline axleshafts and flanges would be needed. @justdifferentials has done this on his own rig and says he could provide the shafts.
1FZ Engine
Ignition - 1FZ in FZJ105 has coil on plug ignition.
Head - 1FZ in FZJ105 has differences in the head. I can’t remember the details @scottryana has done a lot of research.
Transmission/Transfercase
Chassis
Exterior Body
Interior
Please post links to threads with details on FZJ105 parts, PNs, corrections, etc. I am doing this from memory and will make mistakes. It’s really hard to toggle between threads and editing a post on a phone :bang:
I’m interested to hear about upgraded brakes possibilities....
FJ80 Keyed Hi Steer Kit (Pre-order)
“Front Range Offroad offers a must have kit for any FJ80 steering housing. Finally giving you a Hi-Steer option with a brake upgrade! Front Range Offroad has also machined in keyed steering, a stronger steering option that puts very little force on the knuckle studs and instead puts the majority of the turning force on the knuckle itself.
These knuckles are FULLY MACHINED for a stronger knuckle.
Each set gives you an option to run BIGGER brakes without any conversion ring its all built into the knuckle! Run Tundra brakes, CURRENT model 4runner and Tacoma brakes on your FJ80 Axle!”
I looked it up before, I think you gain about an inch of rotor diameter? They are compatible with stock steering arms and ABS.
WARNING! This has been on “pre-order” for a year or more. I like FROR, but they are SLOW! I ordered HD tie rods and ARP studs from them, but it took 2 1/2 months to show up.
Did this actually get off the ground? ...New Keyed Steering Knuckles!!!
Sadly, not yet. I talked to them a couple of weeks ago (chasing down my parts), they said the knuckles were “couple months out”. They seem like nice guys that build quality products but have a huge backlog on machining.
Post showing 10mm hub studs:
While I still think you can never have too much power, it would seem my rear axle studs and dowels do not agree. While loose wheel bearings are a common cause for such breakages, as it was for me the first time it happened, the other times the bearings have been perfect yet the locating pins end up getting pulverised.
The first time I became aware of the issue was after noticing 2 of the 6 studs had snapped just after a tricky section of off road track. Hopeful of making it just a few kilometers back to camp for a repair resulted in spitting the axle clean out whilst traversing a rocky area. Once home and with things apart, the loose wheel bearings were the most obvious cause. Still, I thought there must be a stronger option for the pins and studs. So after some research, I drilled 2 extra 7mm dia dowels and fitted 6, grade 12.9, 8mm x 40mm x 1.25 socket head cap screws (SHCS). And for the best part of a year, all went well.
But over the last 6 months I noticed a couple of axle dowel pins walking out after a bit of driving (on and off road) so I'd tap them back in with a hammer and check the SHCS's for tension. Often they'd be loose but the bearings were always tight when checked soon after. Just recently I pulled the rear axles to check the bearings and take a closer look. That's when I noticed on one axles 2 dowels had snapped and one SHCS was slightly deformed. One the other axle, 3 dowels were stuffed and 2 SHCS were bent. With not enough time for a proper repair I replaced the bent SHCS and only one of the 4 damaged studs, leaving me with 2 pins in one and one in the other. Where the pins had snapped had also deformed the top edge of the hub they seated in so I knew it was far from ideal but it'd have to do for the time being and I'd just take it gently... or so I told myself :)
As an aside, at Xmas I had a Detroit locker fitted in the rear to replace the ARB. I should point out that while I love the Detroit infinity times more than the ARB and I highly recommend them, it would be remiss of me to not admit the Detroit does place added strain on the axles. In normal situations / otherwise standard vehicles, I highly doubt it's an issue to even consider, but when you up the power and torque like I have, and use it, otherwise non issues can become real ones. However, I've come to accept that with great power comes great responsibility in beefing up everything it breaks in its wake :lol: :lol: :lol:
So last weekend after a great trip away (new MTZ's killed it everywhere I went) I was airing up and noticed some oil spatter on the DS rear wheel. Closer inspection revealed 3 loose SHCS. I managed to tighten 3 of them, snapped the head off one as soon as I touched it and the other two felt too dodgy to tighten, so I slowly backed away from the mess and drove home. Once home it was time for a strip down and a good look at WTF was going on and how to fix it.
Removing the SHCS from the already damaged drivers side resulted in another 2 snapping after a few back out turns. The other three came out ok but were noticeably bent. The two dowel pins were fragmented beyond recognition. Removing even standard snapped off studs from these hubs is a right PITA and the dowel pins are even worse being hardened steel. So this sucker is heading straight for the bin. You can also see the deformation on the hub face caused by the dowel pins being overloaded. Some serious force has occurred to do that sort of damage.
Remnants of a dowel pin. One of eight :roll:
The original (285,000km) axles splines and shaft are in perfect condition, especially considering the punishment they have copped over the years. It's testament to Mr Toyota making a damn good product. But the same can't be said for the axle mounting flange. years of beating on it to loosen the cone washers (I know it's not the right way but it's easier sometimes ) and general wear and tear have taken their toll. They'll be kept as spares now...
After speaking with my diff repair guy for a while, he was adamant that despite all the 6 studs holding the axle in, much of the driven load goes through those two 7mm dowel pins in each axle. He's repaired enough of them to know. But first things first was to check the housing for straightness. I did this by bolting on a bare rim to each hub and placed a mark on the lip. Setting both marks plumb I took a overall measurement. I then rotated each mark 90deg and took the relevant measurements. There was barely half a mm in them and with a tolerance of 2-3mm, it was as good as straight. So on with the next step.
The plan was to drill and tap the existing 6 threaded holes and fit the 10mm studs used in the 100s.
This is the 10mm and 8mm cone washers side by side. It might only be 2mm bigger internally, but there's a s*** load more meat on the bigger 10mm cone washer. And that creates a problem...
Here's the 10mm cone washer in position. If I were to have the axle recesses machined to suit the bigger cone washer, It'd virtually blow out the edge of the axle flange in the process. Toyota solved this on the 100s by using a slightly bigger hub and matching axle flange.
So, what I plan to do is this; The 100s also use 2x 10mm axle dowels instead of the 2 x 7mm pins used on the 80s. Just like I did in the original axles, I'm going to fit 4 new axle dowel pins but use the 100s 10mm pins. At 30% bigger and double the quantity, I'm hedging my bets these pins won't be breaking any time soon.
7mm dowel pin hole to left of 10mm pin shown
I'm also going to stick with the SHCS, for no other reason than they're so much stronger than the standard studs, and they make axle removal so much easier since no hammering is required to remove the cone washers. I also have a little experiment I want to try that might go some way to adding further strength to the whole show. Shown is a 40mm and 50mm SHCS. Regardless of the length, they all have 30mm of thread which is perfect as the hub has a thread depth of 30mm (once you clean them out all the way to the bottom using a bottoming tap)
This is a mock up of how the 40mm SHCS protrudes through the axle flange once the cone washer and spring washer are fitted. While there is a good 27mm of thread to get deep into the hub, the threaded section is also right at the transition point of where all the rotational / shear load is. In my non engineering mind, this also creates a weak point for the bolt since the thinnest part is prone to the most shear force.
So my solution to this is I'm considering the following...
This is a 50mm SHCS in place with a cone and spring washer fitted. Same thread length but longer shoulder. After a bit of measuring, I'm thinking drilling the top 7-8mm of the hub so the last bit of the shoulder seats below the hub surface to offer more strength against shear loads. I'll have to cut about 7-8mm of the end of the thread so it winds into the hub fully, still leaving me with more than enough thread depth for a secure purchase. I'll be testing in the old hub to make sure I can get a firm fit in all 6 studs without any binding, along with the very tight fit I need for the 4x 10mm dowel pins.
In the meantime, my new / 2nd hand hubs and axles turned up today. I'll keep you posted on how things work out. :? :mrgreen: :arrow:
105 front axle housing:
Hey @beno did I see somewhere that you had a new axle housing that was maybe a 105 housing and Toyota had made changes to beef up a few things. I can't find the post maybe it was social media? Thanks!
105 steering sector shaft:
Well, next project on the list and has been for a long time is to rebuild my very leaky gear box and while at the same time upgrade to the 105 series sector shaft and pitman arm.
I was planning on doing the rebuild myself of the gear box but after talking with Robbie I decided that I'd better let the pros take care of this as we aren't talking about a $50 assy here (OEM gear boxes from Toyota run well north of $2000!!).
Cruiserdrew keyed me in on West Texas Off Road that specializes in PS gear boxes, hydros, porting, etc. He had great luck with them and the prices are very reasonable. Basically ship your gear box to them (with or without rebuild parts) and they rebuild and paint your gear box and return it to you.
After saving up cash for awhile (new sector shaft and pitman arm are almost $450), I finally made the plunge for the parts. The gear box rebuild kit is actually more expensive than the pitman arm..... :eek::eek:
The sector shaft is a work of art: beefy, beautifully machined, and a big piece of metal.
In any event, I'm very excited to be taking care of my gear box which has been leaking, moaning and groaning for almost three years now under the weight of heavy wheeling and a hot climate.
I'll update this once I get my stuff back from West Texas Off Road.
On to the pron.... :cool:
Best.
-onur
View attachment 374938View attachment 374939View attachment 374940
Exterior Body
While you are correct that the chassis/frame is essentially the same as 80 series, there's loads of small differences. Some things beefed up, some things paired back.
The body is all new, and completely different. Every panel is different, external, and interior.
Electrical is different too.
I think they'll be very little that's interchangeable.
What things were paired back on the FZJ105 chassis compared to the FZJ80? I ask out of pure curiosity, no sarcasm or criticism meant. I don’t think I have heard of anything that was downgraded on the FZJ105 chassis compared to the FZJ80.
The diesels are a different matter, my personal opinion Aussie spec HDJ80 with a 5 speed manual was the best Overlander to ever leave the Toyota factory. It’s a huge disappointment there was no HDJ105. Toyota claimed they couldn’t fit the 2UZ V8 with the solid axle of 105. They don’t have that excuse as to why they never offered an HDJ105, the motor obviously fits.
I want to steer clear of the diesels and focus on what Toyota “improved” on the FZJ105 and how to do the same or similar to an FZJ80 using Toyota parts as much as possible.
Agreed.
I put those sections there as place holders in case Mudders find a way to use something from a newer Toyota on the 80.
For example, my side mirrors vibrate, I like the larger, HEATED, mirrors in my 100. One of these days I am going to see if can get a 100 mirror to fit in an 80 base. If so, then I’d put a link in the Exterior Body section.
Or someone finds a newer Toyota (not Audi, Honda, BMW, etc.) seat that fits in the 80 well, that would be posted in the Interior section.
:cheers:
