Seems your on the right track but maybe an off the shelf bracket would help.
80 Series Front Control Arm Drop Brackets by MAF LC80 FJ80 FZJ80 [PLUS_CasterBrackets] - $295.00 : Extreme Landcruiser, Upgrades for Extreme Offroad Performance
yeah I was looking for something but I didnt know what I would be getting into. but I am going to put a radius on my brackets and reinforce my new crossmember as well. I'm going to stick with the set up I have because I'm on a strict time frame, but that would definitely give it a cleaner look. I'm not super excited as of now with my radius arm brackets but it's the best I could do with the equipment I have. I appreciate the help, I really like those mountsView attachment 1862193
The brackets are boxed in on the back, but I didn't box them in the entire way down, because more than likely these brackets will be getting reworked. I am not completely happy with how they came out, but I needed to get something on the truck in order to finish the steering and suspension.Its the shape of the bracket that worries me. Try to flow the stress in tension and compression. And remember the axle is going to try to twist them off. Boxing in the back of the bracket would help etc
I have considered doing a radius arm flip or custom radius arms, but I am on a limited time frame. I have to drive my car in 1 week. I made this crossmember with brackets, so I can finish working the rest of the vehicle. The mounts are going to be reworked, supported, and I will add strength to the crossmember as well. I am aware the look of this is not ideal, but it will work for fitting the steering and suspension.Consider doing a radius arm flip?
I appreciate the support. I do want to to raise the mounts, as I am not happy with how low they sit. I have half the mount boxed in, in the rear, and would like to mount at that location. I do realize this isn't the cleanest looking radius arm mount currently, but I needed something so I could start working steering, suspension, and pan hard mount. The radius arm mounts will without a doubt be getting re worked for a cleaner look. I am also adding support to the new crossmember as well. I'm trying my best with now break, shear, or any machining equipment. If I would have a little more in the budget I would have done all off the shelf radius arms and radius arm brackets.Quit flaming until he's done y'all.
He has installed it correctly from a geometry standpoint. He will add reinforcements and bracing to support his current design.
If you do indeed raise the mounting location you could use caster correction plates at the axle end to keep the pinion and Castor in line for now.
Carry on, great first draft and thanks for sharing!
It's been one week...did you drive this thing yet?![]()
12 inch travel coilers from fox with remote reservoirsAlso what springs are you running up front?
The placement of the axle is about 2 inches forward compared to the ifsLet's see the new mounts. Looks good from overall though, how much did you move the front wheels forwards with the swap?
What spring rates tho?12 inch travel coilers from fox with remote reservoirs
275/250What spring rates tho?
How much preload? and how many inches of uptravel do you have left?275/250
