Good morning team -
I need to add a fuse tap for the purpose of running my Profile Hi-Lens 2.0 LED high beams on DRL mode. DRL mode requires 12v, so a splitter off the factory high beam wire/line is not working in this application.
Specifically needing advice/direction on what fuse to tap? The only requirement is that this fuse needs to be 'on' as soon as the vehicle starts vs. on a switch or otherwise not 'always on.' I haven't done alot of electrical to date, and don't see an obvious location in the main panel. I'm also aware of the panel in the driver's side footwell, but I'd prefer not to go thru the firewall to access that panel if I don't have to/need to. I'm also open to any other ideas that come to mind, seems like there should be a relatively simple solution to either fuse tap this little white wire or splice it into an existing connection. Thanks for any pointers on this one boys!
