hi folks,
hoping some electrical guru's can help this newb out. been reading another post on a 40 not starting.
so here are the deets/symptoms:
-78 fj40 with a push button ignition switch (no key)
- owned for 5 years, no electrical issues since
- just got gauges installed (water temp, engine oil)
- drove truck home, all was okay.
- decided to clean tidy up some exposed wires in the bay with some wire covers.
nothing disconnected, just covered and ziptied
- gauge cluster still needed mounting and i had to move one gauge over to the middle to make both fit in the old tape deck space
- disconnected ground/ignition/sending unit wire, moved oil gauge over and reconnected exact same way
- tried to start and then nothing, not cranking at all
- noticed the ignition was left on when i was swappin wires on the gauges
- thought maybe i drained the battery (maybe 20 mins with it on) but i have head lights and horn
- i did notice that i have NO turn signals with the ignition on (high beams, brake, tail light working)
- for some reason, while i was tinkering and trying to start, i got lights (in gauges) and the 40 started, this was in the driveway so i just drove the truck in the garage and called it a day.
- next day, fingers crossed, tried to start and nothing (still have head lights) but i did notice the horn wasn't as strong or it would go strong then a weak fart sound not much like a horn, then a strong horn again
- while tinkering out of the blue got lights in the gauges again (not sure what i did) BUT still won't start
- tested fuses, top 3 works on both ends of the fuses, but bottom 3 dont work on either side (i think 20A and 10A and a little shorty fuse at the very bottom). pulled fuses out and tested over battery/+'ve and they work fine
- also replaced a 30A fuse from the battery to ignition (while covering wire/inspecting fuse, i dropped the fuse on the ground, it also had a bulge in the fuse i noticed, tested it over the battery and didn't work, replaced with another 30A fuse which worked, retested with tester light and it still works)
what'd i do when i was monkeyin around with the wires???! arrrgh!!
fry the insides of ignition switch? is this why the lights in the gauges are somewhat going on...?
i have a marine deep cycle battery, could 20 minutes of ignition on (not knowing) enough to weaken the battery to at least have lights but not enough juice to crank? it doesn't crank, not even a ticking sound attempting to crank, just blank when i try to start...
- oh yeah, tried to boost and still nothing...
ground on gauges work, sending unit lines from both gauges look fine, one wire from gauges i believe goes to the ignition button.
not sure if i did this right, with tester light/grounded, i touched the igntion wire to the gauges and with the igntion on...no light...i pulled the ignition switch to inspect physically but no loose wires or broken solders... is it busted inside?
what else can i do to try and diagnose?
please and thanks!!
please and thanks!!
