I’ve had some requests for my wheel and tire setup so here it is.
D551 Trophy
Wheel Size: 17x8.5
Bolt Pattern: 6 on 5.5
Offset: -6
Backspace: 4.5
Finish: Matte Black
Spec sheet - http://www.fueloffroad.com/specs.cfm?id=3330
Goodyear Wrangler DuraTrac - LT315/70R17
Bolted right up with no interference. Center bore clears fine. Supplied FUEL wheel caps do not fit over the hubs. You could modify the caps by spacing them out about 3/8” but I did not want to do this and I like seeing the hub. Tires slightly rub the front running board under articulation but not enough to cause damage. This will be eliminated when the running boards come off. Ordered wheels from 4wheelparts.com during a sale and got the tires from tirecrazy.com at $100 less apiece than any local shops. Once everything came in and I dry fit the rims I had my favorite shop mount and balance. I then had the joy of mounting them up and checking clearance. With wheels forward they just barely stick out past the fenders. Worked out great!!
D551 Trophy
Wheel Size: 17x8.5
Offset: -6
Backspace: 4.5
Finish: Matte Black
