Must be the time of year for fuel tank/pump woes. Elsewhere I saw someone with trouble once they replaced their fuel pump.... I wish i was to that point:
I'm having a hell of a time getting the tank out of the vehicle - after getting the spare tire off (which was a trial in and off itself) and removing the spare tire cross member, i finally got to the point of disconnecting all the hoses when the main fuel hose form the pump breaks off!
It looks like the metal had rusted to the point of being too brittle, and when I tried to unscrew the hard line from the soft line connector the hard line twisted and then broke off. More on this in a moment.
So after getting the tank loose, I can't seem to wriggle it free from the between the frame rails - what am I missing? It looks like I need to remove the rear sway bar bolts - is that correct? (Of course this seems to be causing it's own issues since it too is frozen in place (even though the links are on the newer side).
So I have two questions:
First do i NEED to remove the sway bar bolts? Or can the tank be finagled out with out doing that?
Second, what should I do about the busted hard line from the fuel pump itself? Is it easy enough to fabricate something there? Or will I need to buy a new injector (or whatever its called)?
This has turned into a much more frustrating job than I was ever intending - what am i doing wrong?
