Fuel Injector rebuild and refresh (5 Viewers)
Aside from the toyota parts, an injector cleaner and ultrasonic tank really help. I have a cheapo harbor freight ultrasonic cleaner which does admirably cleaning carbs etc.
Injector cleaning device which triggers the injector while you run solvent through it. Just connect to 12v supply.
I wired up a proper connector to the injector cleaning kit so I didn't have to worry about the clips coming off. P/n: 90980-11875. May only work on 06/07 MY.
Has anyone ever seen the isolator (96721-24015) split after being replaced? Replaced all three pieces with OEM when I rebuilt the engine about 2 years ago and I just noticed most of mine were cracked and split. Not sure if it was a fluke or what.
Can you please check if the length of the filter is 13.8mm when you get your new parts?
I only opened one of the 2 boxes of parts, but the filters I received are 11.2'ish mm.
Haven't pulled the OG's to verify their length and if what I received is correct.
I
I wonder if they had been sitting on a shelf for a long time before you bought them?
