OK, Last night I went for a drive in the crisp Texas evening, and discovered that my fuel and temp gauges were not working... again...
I thought I had this sorted out!! About two weeks ago I put in a new gauge cluster, and they worked just fine!!
About 5 minutes into the drive, the gauges came to life. At stop lights, i noticed that the gauge cluster bulbs would fluctuate, get dimmer, then when I would go, the bulbs would go back to a brighter normal.
This is the new symptom; My Fuel and Temp gauges were doing the same thing!! At the stop light they would die, or drop low, then when i would accelerate they would come back up. After about 20 minutes of driving around, the cruiser was warmed up, and I experienced neither symptom again.
Has anyone else with the Fuel and Temp gauge problem noticed this? Could this be an underlying issue with the generator or voltage regulator?? Or bad connections, which have been checked, re-checked, cleaned and re-cleaned.
Tell me what you think guys...
Another question is does everyone elses fuel sender wires run on the outside, underneath their cab, or is mine a hack job by a PO?
