FSM for 200 series
Yeah, unless you set Windows up to auto mount the ISO image when it boots, this step needs to be done each time the PC reboots.
I was able to get the ISO to work in the web browser on Windows 10 without the need to install any third party tools.
  • Go to: Programs and Features > Turn Windows features on or off
  • Check "Internet Information Services" (the default partial select features should be sufficient)
  • Click OK and let it install what you just selected
  • Windows Key-R and enter "inetmgr.exe" to launch the IIS Manager
  • Expand the left pane until you're at "Default Web Site"
  • Right click on "Default Web Site" and select "Add Virtual Directory"
  • Give it an alias of your choice, perhaps "ToyotaFSM"
  • Select the drive the ISO has been mounted to for the physical path
  • Select "Default Web Site", then double click "MIME Types" and add a new MIME type for File name extension "jsp" and MIME type "text/html".
At this point, you should be able to view the contents of the ISO in a browser on your PC at "http://localhost/ToyotaFSM/". If you want to access the FSM when you're out of the house, you would need to setup port forwarding or VPN access on your router. To access it from other PC's (or iPad or other device of your choice) in your home, just replace "localhost" with the IP address of your PC.
Nice
I'm not sure if everything will work with the /ToyotaFSM/ path appended. It might, but the website has some weird coding and I'm not 100% sure every path is relative. If you run into issues, try adding it at the root (/) instead of in a subdirectory (/ToyotaFSM/).
Nice
Thanks for the tip on potential path issues. I haven't run into any obvious issues so far, but I haven't used it extensively yet either. The same thing should work for most recent versions of Windows.
FYI I'm told that for Mac the only difference being that Macs natively mount disk images under the "/Volumes/" directory. Pointing the web root to "/Volumes/TLC FSM" is what was needed.
I'd be happy to confirm/deny that if someone has an old Mac they want to give me ;-)
is anyone running this on a MAC? I'm having a hard time understand how to create a path to see the file.
Edit: Nevermind. Answer above.
okay. Got the path but this is what I get when I goto 127.0.0.1
I suspect either the ISO isn't mounted, or it is but the path isn't set up in the web server. I don't have a Mac available to test this though.
If you log into the admin interface (http://127.0.0.1:9999) you should be able to view the web server logs and see if there are any errors. Failing that, go back to this post on page 3 and take screenshots of the same screens I did and post them here
Is there someone who could upload a few FSM screenshots? Looking for directions on replacing the power steering pump on a 2008 LX. TIA
Yes, I PM'ed you. Let me know if you need the disassembly/reassembly instructions too or if just the remove/reinstall is sufficient
FYI I now have a torrent available for the FSM, which should improve download speeds/times for folks. PM me if you'd like the URL to help seed for others. You'll need uTorrent or another bittorrent client to download and seed.
I purchased a 2010 LX570 Toyota factory service manual CD off eBay and ripped it to ISO.
How to use it: Download the ISO, Open the ISO, locate the mounted ISO (appears as a CD Drive) in My Computer and run autorun.exe
Does that have all the US docs? If it does that's great. A bunch of the early FSMs were the 2008 version (RM0800U) and didn't include the 3UR-FE
I've got a lot but not all of the docs...
I successfully installed the webserver and everything I've tired works except the wiring diagrams. Clicking on the link pointing to /TOYOTA/LAND_CRUISER/rm2660e/ewd/index.html causes a Error 500, internal server error.
The directories and files in that path are present and I can open the PDF's.
Suggestion?
