Need some help diagnosing a strange front end bounce. When I hit even small bumps on the road at any speed, my front wheels seem to bounce like crazy. The body isn’t bouncing, but the wheels seem to be over responding to the bump. I can feel it inside the truck for a few seconds after the bump.
About 6 months ago, I installed OME stock height springs with oem shocks. I drive on washboard dirt roads 90% of the time and thought the oem shocks would offer a softer ride. The truck has some roll and bounce too it, so my suspicion is that the oem springs are too weak for the OME shocks and that could be causing the over exaggerated wheel bounce in my front end. Thoughts on that?
FYI: in the past month, I’ve replaced tie rod ends, adjusted wheel bearings, installed new tires, new steering dampener, new front sway bar bushings and hardware. (All things that needed to be done but never fixed the bounce...I wasn’t just chasing the problem).
Everything in the front end is tight when I’ve jacked it up to inspect...except for a small amount of play in the caster bushings.
I don’t want to change shocks and/or caster bushing unnecessarily. What else should I be looking for? Are the shocks too weak? Are the caster bushings to blame? Other ideas?
Thanks for any help.
