Front Wheel Bearing Nut Socket - Lite-Weight Version?
Sarasota, Florida
I'm getting ready for an extended trip and am looking at my tool list. I bought a 2 1/8 Craftsman socket years ago for wheel bearing maintenance on the 100 but the socket, and it's needed 3/4" - 1/2" drive adapter, weigh a ton and are way overkill for the job. Has anyone found a lighter weight alternative to a standard socket that fits the nut? Since the torque is so low a cheap stamped steel type would suffice but I haven't able to find one at local auto part stores. I realize that, in the scheme of things, the extra weight isn't really that much but it still bugs me to carry around that excessive hunk of steel when I could be applying the weight to something really important - like another bottle of beer!
Search for a 54mm socket. Tons on Amazon.
Cruiser Outfitters sells a 3/8" drive version- not really sure that it's light weight but it's a quality tool.
Make one. Just bend a piece of steel to 54mm and weld a socket that you don't need, or have multiple of, to the end. That way you could have any sized drive you wanted like so:
check with a plumbing supply house you can find the cheap stamped steel one you are looking for... i made my own out of a scrap of muffler tube heated up the end and formed it around a nut.... ( was a cast iron gas pipe fitting if i remember right) took 5 min to make tempered (cooled it in old motor oil) drilled a hole in the non formed end to use it like a factory supplied motorcycle spark plug wrench... light weight and you could store other tools inside it....
Thanks for all the replies. I guess I didn't search hard enough. Now I know!
TheForger, you really are a "forger"! Good job on that piece of artwork!
The cheap stamped ones will round out after a bit of use. Get a real one. The fellas have posted you to some good options.
I found this 55mm one at my local Napa and it is 1/2" drive and works just fine, it was fairly cheap too. Way lighter and depth is no longer an issue either.
I have one and it started to really bend when I had a stuck spindle nut on one of my 80s. I ended up having to buy a proper 3/4" drive socket to get it off. Just something to keep in mind if the nut won't come loose.
Thanks all,
I ended up finding the OTC 6612 one on ebay at a good price with free shipping so I bought it. I liked that one because my torque wrench is 1/2" drive too.
