snip
And per others: Remove and throw the J hook away...no bueno for anything more than holding the LC to the shipping container for its ride over from Japan...
Here's my stock 200 one and the tundras are larger.
No no no no please do not use those tie down points as recovery points unless you have nothing else at all! The hook is alright to use for recovery.
http://duiser.com/shop/100-series-accessories/100-series-recovery-point-urb-pair/ on the front will work great. Make sure you torque your bolts back up to spec if you do purchase something like these.
If you have a proper tow hitch receiver (not the in bumper one), http://www.amazon.com/Smittybilt-29312B-Receiver-Shackle-Receivers/dp/B001CF1A7O?tag=ihco-20 will work as a proper rear recovery point.
Now, in a pinch (no other choice), you can theoretically fit a 3/4" d-ring shackle through the tie down point, but there is a much higher chance that it will give out. Any kinetic recovery is generally a big no no with tie down points, but dead pulling can be done... winching would probably be the safest bet if you have to use the tie down points.
Based on the threads in the sponsors forum, I would be very very hesitant to do business with Duiser.
