Front Recovery Points
So much for heavy-duty mounts when rust is involved.
My 8 Amp Kobalt 1/2" impact wrench couldn't get my stock bolts to break loose. My 1/2" breaker bar got it off with a nice hard pull. I torqued mine down per the specs I found here a while back.
Breaker bar with a pipe for additional leverage did the job. Thanks.
Anyone know if there is a 3 bolt recovery bracket for 100 series? Reason I ask is the captive nut broke off inside of the frame on one of the bolts when I removed the old ARB bumper. Someone cross treaded and over torqued. So I'm trying to figure out an option for the PS now. Most if not all I see have the 2 bolt hole pattern and the 3 bolt holts under the frame are not evenly spaced. In addition, the one that broke is the middle bolt hole nut. So I'd need a longer/extended bracket in order to get things to line up. I suppose I can contact a welder to see about fabbing something up, but figured I'd check the market out first.
