Just swapped a new set of gears on my FJ40.
Now they need to break-in. As usual I need to make ~20-25 short trips of around 25km (15mi) each to let them warm up while driving and then slowly cool down for at least 15-20 minutes.
The rear is very simple, just driving it. The question come for the front.
In normal 2WD condition only rear gears are rotated as front driveshaft is disengaged in the Transfer Case and not rotating. If I do switch to 4HI only, it will rotate the front driveshaft, would it? In this case front gears will be rotating, but without any load. Would it be sufficient for breaking-in or do I need to load them up?
FJ40 has a part time 4WD system which means I can't use it on dry asphalt. If I do engage the hubs and my understanding both have to be engaged as only 1 would not do the trick, I can only drive on a straight line and no turns.
So, what is the best way and the right way to break the front gears in???
