Front end grinding noise, truck won't move FAQ thread (2 Viewers)
Trunk Monkey
Moderator
Salt Lake City
Getting a thread going for the recurring posts on front end grinding noise and truck not moving.
Symptoms:
grinding noise from under truck, specific to front end
truck won't move in drive or reverse, grinding noise if attempted
Likely causes:
c-clip has popped off the end of the CV shaft
axle and/or flange splines have stripped out
Temporary fix:
lock the center differential, you can drive with just this for emergency purposes, but you will cause further damage to the splines
for a longer fix, remove drive flanges, remove front drive shaft
Fix
inspect flanges and splines, replace c-clip and other parts as needed
you may be able to replace just the outer shaft portion of the CV
some have even been able to just replace the c-clip on the axle and been good to go
Thanks to @trdcorolla for looking these up:
CV (Driver and Passenger Same P/N) 43430-60040
CV Outer Shaft Only (Driver and Passenger Same P/N) 43460-69145
Drive Flange (Driver and Passenger Same P/N) 43421-60060
Driver Side Oil Seal 90311-47013
Passenger Side Oil Seal 90311-47012
Snap Ring 1.8 90520-31010
Snap Ring 2.0 90520-31009
Snap Ring 2.2 90520-31008 (Factory Size Per 2001LC)
Snap Ring 2.4 90520-31007 (Most Common Per 2001LC)
Snap Ring 2.6 90520-31006
Snap Ring 2.8 90520-31005
Pic of CV end c-clip sitting in hub flange dust cap.
img_20210527_154639-jpg.2686235
