Front differential fzj70
876 Cruisers
KZJ70/FZJ70/HJ47/HDJ80²
Jamaica
Hey all,
I have a fzj70 and a tooth on my crown in the front diff broke.
The replacement part is expensive and I'm wondering if any other 4x4 vans have the same or similar crown and pinion. That could work.
4.11 ratio 37:9
Also is the dif reverse gear?
Regards
Dan
Same part number for the 1990- 7*, 8* and 105 series, non locker type.
You can get all that for $550
Hey all,
4.11 ratio 37:9
Regards
Dan
80 series front will go in. Gear ratio difference is not worth mentioning. (80 is 4.10, so 41:10)
Thanks for the replies . The 80 series one sounds like a good option seeing that I may can find that locally easier and probably cheaper than brining in a crown and pinion
