Well, after grinding my brain all week, here is what I decided to do. First, the FJ80 front axle is a weird beast indeed. Steering will be next to impossible to do correctly as they use only a two-bolt bearing cap on top of the knuckle, the shafts, birfields, and knuckles are all very different from 60s, so swapping parts isn't going to happen. I already have the correct gears for my ride, and Longfields as well; tossing all that doesn't make sense. So, I paid a visit to Kurt at Cruiser Outfitters on my way home from work last Friday and picked up a 60 front housing. I'm did some measuring, and I will have to extend it a total of six inches to get where I want to be, that is, matching the rear in width and NOT running stupid wheel spacers. Poly Performance will make the custom length shafts for $350 out of the 4340 or whatever that is; they say it will be twice the strength of stock, which I never broke anyway, so I should be fine. The tie rod and drag link will need to be longer also, I might make my own as I have access to the materials. So that's it, I'm going to add three inches to each side as well as larger 4-runner brake calipers and a master cylinder from an FJ80 to drive the four-wheel disk brakes that I have. It's time for trunion bearings and a steering upgrade anyway, and I really should raise the front pinion five degrees, so I will do it all at once and stuff in a complete assembly. I'll try to take pics so everybody can make fun of my redneck engineering! But hey, I have never had a weld fail and I'm not planning on making a weak axle out of this; it will be overkill if anything so stay tuned!
