- Thread starter
- #61
is there any easier way to remove the pins off of the rear shackles?
I think Bikersmurf is correct and those spring plates are upside down.
are you saying my springs are backwards, or my shackles are upside down?![]()
No...like they both said..."spring plates".
could be the pic, but they look wrong to me too...
Ran into a bit of trouble today, it seems my rear OME Heavy spings are too short, any ideas on how to make them... longer?
would it change the ride if the springs were backwards anyways?
as for the spring plates, what do you see is wrong?
Not much. You might need to park across a ditch with two wheels in it to sofften up your springs.
Spring plates upside down will create a strespoint leading to preamature failure.
I wouldnt pull the pin from the hanger its a bit harder to line up ...
I would recommend that u mount the springs on the hangers ... Mount the springs to the axle.. U can use axle stands or mount the tires to the axle... mount th shackle to the frame.. Or to the spring... Then strap a block of wood to the frame in front of the shackle .. Then use the weight of the truck as u lower it down to flatten out the spring so u can put the last bolt in the shackle... Grease your bolts and bushings.. Makes installing them easier...
