Formula used to figure out gear ratio to use with new tire size - Opinion on which gear size to use?
give me your email and I will send you an excel file.
you should not be re-gearing your truck, you should merely swap the speedo gear to account for the adjuster rpm.
I personally would not swap gears until 35s on stock transmission. EVEN with an HFF. FYI Transmissions do not affect the speedo if the gear is the same for the
I am personally going to run 3.73s with 33s to get better gearing on the highway at 65-70. I may eventually make the H41/h42 conversion to pick up teh steeper 1st gear and get back my off the line clutch rollout. 3.73s with 33s will require a little more feathering.
Stock tires are closer to 29 IIRC
This is how I made my decision.
Guys thank you this forum is awesome as usual. I checked out the formula sheet FJsnoozer, excellent! You are right I think the 4.11's is good where it is at.
