ARCHIVE Forge Specialties: What are we working on?
nice fab work as always
Thanks!
The same 100 series had some rot towards the back of the frame. It turned into a classic case of 'the more you dig, the more rot you find'.
...exploratory surgery.
Both sides of the crossmember, as well as the frame, were paper thin and swollen.
It took this much chopping to get to solid metal.
...the first patch.
...fabbing up the second patch.
We put an extra hole towards the frame in the bottom of the crossmember, in attempt to prevent the rot from building up in the same low spot again.
...drilling the hole for the wiring harness.
...reassembled, with the wiring.
It's difficult to see in the pic, but the plug is in a pretty tight spot and very well protected, once the front diff is reinstalled.
Before and after pictures on this project aren't terribly dramatic, because the truck looks exactly the same at the end. Traction is not visible to the naked eye.
...and because EVERYTHING needs lockers...
We've got an '08 F250 with a turbo diesel, 6spd manual, a vinyl bench seat, and manual windows and door locks:
...getting a pair of ARB's, plus a few other goodies.
DANG you guys are GOOD!
Thanks!
We aimed high and went with the monstrous ARB Dual Compressor for the F250. Since there is NO WAY that this compressor will fit under the hood, we had to look for other real estate. We settled on the passenger side frame rail.
...sharpie-ing out a mount bracket, to bolt up to existing holes in the frame.
...trimming, punching some holes and dimple dying it(you know you're fabbing when you have sharpie AND dimple dies).
...adding hardware, tacked in place for easy removal and install.
...mounted on the frame, with the compressor.
How do you set preload and backlash on that clamshell front end?? :hmm:
For packaging purposes, we mounted the air manifold, solenoids and air chuck near the rear bumper.
The manifold mounted to two existing holes in the Ford frame.
We're plumbing an air chuck into the rear bumper.
This ends up being a very handy location for a vehicle that does any towing. A conventional air hose can easily reach any of the vehicle tires or the tires of just about any trailer your towing.
The stock front diff cover was rusted and gross, so it was a perfect time to swap it out for a Solid one.
The BEEF!
...front axle teardown.
The front U-joints were whipped and they REALLY didn't want to come out.
