ARCHIVE Forge Specialties: What are we working on?
We just got in a pair of Harrop ELockers for a 200 series install next week, from Can Am Cruisers. @wardharris
Here's a closeup of the handy little Bussman fuse/relay block and the battery separator.
The engine bay is starting to come together.
We're working on having some FJ62 LS-specific radiators developed. An aluminum stock application 62 radiator(left) vs an LS 62 radiator(right):
...burning in the engine mounts.
...scrubbing down the engine bay...oh the glamour...
...bending up some fuel line plumbing.
This pile of bling is about to become a stainless Y-pipe. We are connecting it to the existing stainless exhaust on the truck.
The existing cat gets a V-band flange.
The original 3FE ECM mounting brackets are used, in conjunction with a little extra sheet metal, to mount up the Dakota Digital tach signal box. This tucks the extra electronics up into a factory position.
...all mounted up in the truck.
Does this count as an FJ62 infestation?
One of the handiest things about this swap(aside from the POWER) is that it's now OBDII.
...fabbing up an OBDII connector bracket:
...tucked up out of the way, but still in a conventional OBDII plug location(under the driver side dash):
It's out of the way and not visible unless you're really looking for it.
The stock transmission crossmember gets modified to accept the new transmission mount.
...mock up:
