For Sale @ High Desert Cruisers (12 Viewers)
Anyone need a 285/75/16 AT (dont remember brand) that has 2/3 tread left? I got it from slimbuddha about a year ago and have used as a spare (carried).
Id be interested in that one also, especially if has more thread on it then the one Corey gave me.
No road salt or chemicals from snow areas but saltwater proximity may be harmful. If I was looking for a 100 I would not rule it out until I was able to get eyes on the undercarriage.
I have retired and need to get my garage in order.
I have no use for the following and have attempted to price items to sell looking at sold prices on MUD when I could find them. So if you do not think that the posted price is justified, please let me know your justification for reducing price, or just make an offer.
Several items are listed as free with purchase of another item. Intent is to give one free item with purchase of another item of equal or greater value.
I do want this all gone.
I have photos of each item I can send to anyone interested, unless otherwise noted, and can take additional photos.
There will probably be more items listed later in a new thread.
I have given part numbers where possible and researched applications when I could, however you need to verify parts fit your application on your own.
1. 2F rear main seal #90311-99001 $30
2. 100 series LC drive shafts, removed at front 152k, rear 168k miles. Shop ticket number suggests they have been rebuilt. Removed when trying to eliminate drive line vibration. $75 each
3. 100 series LC front CV shafts. Removed when trying to eliminate drive line vibration. $40 each
4. 100 series LC headlamp upgrade. Higher wattage lamps modified to fit LC. 4 extra new in box lamps. $50
5. 1975-80 2F smog pump, valve, hoses
6. 1982 smog valve and hoses
7. 19100-60064, 1971-73 distributor
8. 19100-61021, 1976-78 distributor
9. 029100-61020, 1973-77 distributor
10. 31210-60070-84 clutch cover removed from 1987 FJ60 at 20k miles of use. Replaced when installing 5 speed tranny. I have documentation on the mileage. Machine marks still apparent. $75
11. 87249-90A01, 1981-87 rear heater inlet hose $5
12. 87249-7502085-87, FJ60 rear heater outlet hose $5
13. 88840-14010, AC “O” rings for FJ60, $2 or free if you buy another item
14. 90334-07009 head plug $2, Free if you buy another item
15. 90521-34003 snap rings $2, Free if you buy another item
16. Approx. 85’ of 4 pair data wire, makes good speaker wire. $2, Free if you buy another item
17. AT strainer for 1998-2003 LC $20
18. Carb, 1973-1974 $75
19. Carb 1977 $75
20. Carb 1981 $75
21. Cargo hold downs $5, not sure of application
22. EGR cooler, 1 of 3 units $50
23. EGR cooler, 2 of 3 units $50
24. EGR cooler, 3 of 3 units $50
25. Exhaust cushion and AC compressor gaskets $2, Free if you buy another item
26. FJ60 4X4 badge $2, Free if you buy another item
27. FJ60 Land Cruiser badge $2, Free if you buy another item
28. FJ60 interior door handle trim $2, Free if you buy another item
29. FJ60 interior light switch for door, includes door stop pin and random breaker $2, Free if you buy another item
30. FJ60 HAC valve $10
31. FJ60 heater fan $35
32. FJ60 ignition switch $20
33. FJ60 mud flaps $2, Free if you buy another item
34. FJ60 rear side vents $2, Free if you buy another item
35. FJ60 rear spring mounts and U bolts $15 for the pair
36. FJ60 rear window washer bladder and pump $25
37. FJ60 Smog BVSV $5
38. FJ60 SS gutter trim $15
39. FJ60 sun visor pair $20
40. FJ60 transfer shift lever boot $10
41. FJ60 tailgate one $50, some bondo and primer
42. FJ60 tailgate two $60, looks pristine
43. FJ60 windshield gasket and SS trim $20
44. FJ60 wiper screws $2, Free if you buy another item
45. Front license plate holders FJ40, 45, 55 $5 each
46. Hardface weld rod $5
47. Ignition resistor 1976-1978, new unused $10 #90919-04020
48. Igniter assembly for 1975-1977, untested $5 and return within 2 weeks for refund if it does not work.
49. Intake Snake for cleaning throttle body $20 http://www.run-riteracing.com/industry/9710.html
50. MAF sensor for 1998-2006 LC, 2003-+2005 4Runner. Ran for about 5k miles while trying to eliminate drive line vibration $50 #22204-75020
51. Manifold cool fan #16360-61015, fits 1981-80. $20
52. Non USA mirrors for *J60, excellent condition, $200 for the pair. May fit 62 series.
53. Smog air rails $20 each
54. Blue VSV $2 or free with another part purchased
55. Speedo cable thing, have no idea of application. $2, Free if you buy another item
56. LC tow hooks for 100 series $10
57. Utility lights. These were brake and back up lights for Terex mining trucks. Mount is ½” threaded stud. $15 for all 3.
58. JF60 factory wheels from 1987, I have 9 for sale at $50 each. No photo
59. BFG All Terrain, LT285/75R16, Load Range D, there are 5. Tread depths of 6/32, 9/32, 10/32, 6/32, 4/32. $60 for all five. No photo. Want to sell as set, so if you only want partial, you will need to get rid of the others yourself.
I'll take those tires all 5. Perfect to see if they'll work on my tow rig
Let me know where, I'll see when I can be there
Well, it’s time to get rid of my ’99 4Runner. Excellent condition - Addicted front bumper, Stubbs HD-SKO (Heavy Duty - Single Kick Out ) sliders, BudBuilt skidplate and belly pan, TAG rear bumper with tire and gas can carriers, Rear Toyota Electric Locker, OME 2.5" lift, BFG MT-KM 285/75-16 tires, Smittybilt XRC 8k Winch, Alpine CD/MP3 into an AudioBahn 75x4 Amp, Viper w/shock sensor and immobilization, new Red Top. 220k miles - nothing but Amsoil after 40k miles. Listing it here first. $8k obo. Text 5zero5 niner eight zero 0303.
More pics available
I'd be interested in all the 100-series stuff. Did you ever figure out the driveline vibration? Is that why you got rid of it and got the Jeep? I've got one if I go over 65 and it seems to be setting up some sort of harmonic frequency vibration as it is not just a constant vibration.
Being retired, does that mean you'll have more time to hang out with the gang?
Liquidating and moving to Florida with all the other old farts? Or trying to raise capital to get the cabin going?
The vibration was most noticeable during heavy acceleration, then while maintaining speed up a steep hill, also when accelerating with the camper trailer attached. I had installed OME springs for about a 2" lift, and also the Slee diff drop kit. I finally decided that the issue was the angle of the front drive shaft angles with respect to the front diff changing under the above conditions, all of which will raise the front of the truck. Dave Lawrence mentioned that he had heard of others which had suffered the same symptoms. So I think every 100 series part I am selling is the result of trying to find the source of the problem. And yes, I did buy the Jeep to get away from that issue. And the Jeep has surprised me, as I have had no issues at all. Unless you consider the visual issues of fit and finish.
So Marc, please give me a phone call. I have to post my phone on this forum, but it is already on this link, under Placitas:
https://www.nmgco.com/Home_Energy_Raters_SP.aspx
Could be, I like the overnight trips with on the trail camping. Do plan on getting back into fly fishing. Have lots of things to do on the house. Going to firing range today. Giving a FJ55 that I have lost interest in to my son, and am installing a tulrbo on the BJ and restoring at least one FJ45 pickup which will include fuel injection.
I know that Vince and I both like 4-wheeling and fly fishing, especially when you combine them.
My vibration is more pronounced when I am towing something. I've considered maybe I've got too much grease in a slip yoke and it has hardened up to one side and made the shaft go out of balance. But I haven't had any time to take them off and investigate. The U-joints all seem very tight. I grease the entire driveline about every 5k miles or when I hear the slip-yoke clunking but I bought the trick with 92k miles so I don't know its history before that.
I would try air bags and see if you can get hitch height back to what is without trailer and see what happens. You can spend a lot of time and $$ chasing ideas.
  • Back
