- Thread starter
- #61
Yes, the center of gravity might be slightly lower with the axle lower. What I am trying to says is that I believe John feels his truck is more stable since it does not lift it's rear wheel as often as it did on rutted roads.
However I do not believe it is more stable (by saying stable, I say less likely to roll over when pushed to the limits). Yes, in limited cases the wheel will droop out more and may or may not still be contact with the ground.
Does it help with traction, maybe, but only if the wheel has downforce on it and is actually allowed to grip. If the axle droops so far that the spring unloads and there is no downforce on the axle, then there is no pressure on the wheel and it will do zero to help with the traction to overcome the obstacle.
Can he drive further up a ramp or rock without lifting his rear tire. Yes, does that mean he is stable no. If you ever studied Ben's old 80 you would see that he could drive to the top of our ramp at the shop, however was that truck stable to wheel. No.
My ShortBus goes about halfway up our ramp, however it is 100% more stable than his truck used to be. Why? Less travel and retained springs that has both possitive and negative spring tension. So the axle is never allowed to droop freely. Once the axle starts pulling down on one side, it starts to pull the body down as well and thus leveling the truck.
