ats4x4dotcom: Enough already
Do you offer a complete, matched, 4-shock/spring solution for our LC 100's that provides additional benefits/performance over the current OME standard? If so list it up please.
ats4x4dotcom said:We have a comp shock which is 760mm long, and convert the top rear mount on the vehicle to an eye mount, allowing it to be mounted higher near the floor especially with a body lift to run 37's, using a bump stop spacer to stop the 37's dining on fender when articulated, this shock is 450 ish mm closed.
The spring has to be held captive with these shocks normally also.
Greg B said:With a lifted 100 running 35's, this is not the case. In order to run the 35's, you have to use a bumpstop extension to keep the tires from rubbing in the fender wells. So, using an N101, you just lost two inches of up-travel. Which is a real trade-off for some people; loss of suspension travel to gain ground clearance from larger tires.
Now, go and add the N74L's like John did. You just got your full range of suspension travel back that you had before you started running 35's.
If you can't see this for what it is, then you're being stubborn because you don't want to agree with John.
SINCITY100 said:Hmmm.. If this is true..Should I bother installing this mod untill I put my 35`s on my rig ? I currently have FULL suspension travel with NO rubbing with my 33inchers..![]()
I understand there is a benefit when running 35`s, but I dont want to lose anything (articulation) with my current tire selection...
Umm...HELP ?
Umm...HELP ?
ShottsUZJ100 said:3 things:
When you're ready to replace your tires....add the N74L, 863, AND 315's at the same time. Your end result will be an amazing improvement. (In looks too) The truck will drive off-road like an 80 though with all the benefits of the 100.
Greg B said:I agree with John's thoughts on his post. But, there is another option you may want to consider. I'll give you my plans to consider.
My Slee rear bumper is on it's way. I am going to install 863's and N74L's when I install the rear bumper. Even though I am currently running 295 AT's I will still gain .6 inches of travel with this setup with no ill effects.
However, I am also going to get a set of 35" MT's for local wheeling that I will throw on when I need them. With this new suspension setup, I can go from 33's to 35's at will with no suspension issues on either tire size. That is called flexibility and I like it.It is nice to have options, and I think this suspension will give me the options I'm looking for.
SINCITY100 said:SAounds like a good plan to me Greg...
Maybe I will wait and see what you think (after installing your 74L`s) before I slap mine on...![]()
One more tester is always good![]()
I am gonna go a bit "unconventional" for a 100 (imagine that !) when I do my 35`s...Real narrow with a real aggressive tread..should be interesting![]()
ShottsUZJ100 said:ANOTHER OPTION!![]()
Do what I've done (because I get excited and can't wait.). Go to your tire shop and get your tires NOW. Since they have tread left you'll get $25-50 per tire trade-in. If you wait you get no trade. Helps ease the change and your truck is DONE. Ahhhhhhhhhh......the feeling. POKE! POKE! Slap it on the plastic the go spank the Jeeps!
SINCITY100 said:I did get some driving lights for the ARB today...I will post some pics when I get them on.![]()
ShottsUZJ100 said:See! I was correct! You are in SICKNESS-MODE. Sell those 33's (easy!) and finish the truck now. Here's a credit card to use:
100-315-75-16
Exp date:
JAN/2006
Name on Card:
Joe KillaJeep
Phone number:
1-800-CRZR-SIN
SINCITY100 said:Hey John...I think you made a mistake on the card# or something...I just called the TireRack to order those 35`s...and it was declined !!....(insufficient funds or something like that !)...![]()
I guess I will just have to wait ....![]()
100-315-75-16
Exp date:
JAN/2006
Name on Card:
Joe KillaJeep
Phone number:
1-800-CRZR-SIN
Greg B said:I called Christo to order some more goodies. He said this credit card info you posted is no good. He said your account had a different card listed on it. So, he applied my charges to it. Thanks John!You da man!
Greg B said:So, what you're telling us is you really have NO WAY of putting a longer shock than an N74L on a 100 equipped with a standard 2-3 inch OME lift.
ShottsUZJ100 said:What have I said a million times?
IDIOT IDIOT
OK, I got it now. Pictures don't even work for me!![]()
spressomon said:ats4x4dotcom: Enough alreadyDo you offer a complete, matched, 4-shock/spring solution for our LC 100's that provides additional benefits/performance over the current OME standard? If so list it up please.
FirstToy said:DMC,
denial ain't just a river in africa.
on another note, seriously throw some of those 120 &100 recovery loops in if you send stuff to Slee! I know he will sell them all
