Fluid Replacement FJ40 1977
Discussion in '40- & 55-Series Tech' started by ptefj40, Aug 10, 2018 at 4:40 PM.
  1. ptefj40
    ptefj40
    72
    14
    Apr 5, 2018
    Boston
    Hi All,
    I decided to do a fluid replacement whilst I have the transmission hump in the shop for repainting. This is the truck that I bought in pieces from NC.
    I managed to get the fluid drain plug out on the transmission and the transfer case. The fill plug is completely gnarled on the transfer case BUT I got the breather nut off with a 27mm socket - phew!
    In the process of draining the transmission, the old oil is white, milky and horrible. I've let both the transmission and transfer drain for 1/2 a day or so.
    Couple of question and advice.
    1. Can I fill up the transmission with new oil, or is there any other flushing of the system I ought to do before refilling with new gear oil?
    2. Can I refill the Transfer Case with new gear oil via the breather hole at the top with the correct quantity? I found on the board that the TC without PTO takes 1.8 quarts.
    3. Assume the only way to get the stripped fill hole nut on the TC is to weld a nut to it and heat/ice it?
    Help appreciated!
    Best, Phil.
  2. fj40cruisin
    fj40cruisin
    34
    13
    Apr 8, 2017
    Utah
    I don't know about any flushing system but I think you should look into it. Having that color of oil would make me weary. As for the fill plug, I had the same issue. I couldn't get mine off because it was so stripped. I ended up buying a Knipex 8701250 10-in cobra pliers. This tool gets tighter the harder you turn. I think they are on Amazon for $30. It eventually came off and I replaced the plug. You can also try heating the plug. When I completely drained my tc it actually took over 2 quarts of oil. I filled it until oil started oozing out the fill plug then I screwed on the plug. Hope this helps.
  3. ptefj40
    ptefj40
    72
    14
    Apr 5, 2018
    Boston
    Thanks!! I just ordered a set of the magic pliers! Be here Sunday!
    Do you happen to know the size of the fill plugs? I think there was talk of them being replaced with Allen wrench style. Did you do that?
  4. subzali
    subzali
    3,352
    323
    Jan 31, 2005
    Denver CO
    Just get a replacement plug from the dealer. Doesn’t have to be hex up high like that, the hex is for drain plugs that scrape on rocks typically. I would say just fill and go.
  5. GA Architect
    GA Architect SILVER Star
    2,593
    4,783
    Feb 14, 2014
    Woodstock, Georgia
    FWIW - I just replaced all the old drain & fill plugs with new 90341-18021 allen head magnetic plugs on both diffs, transmission and the transfer case. Along with the new allen head plugs, all steel units (diffs & tranny) get steel gaskets (12157-10010) and the aluinum T-case will get the auminum gaskets (90430-A0003).
    [​IMG]
  6. fj40cruisin
    fj40cruisin
    34
    13
    Apr 8, 2017
    Utah
    I just got Toyota fill plugs from SOR. I believe they were 24mm socket.
  7. ptefj40
    ptefj40
    72
    14
    Apr 5, 2018
    Boston
    Thanks guys, just went down to my local dealership and ordered the parts...easy! I also got the Yankee Toys discount rate. Each plug was 2.44 each and the crush washers just over a buck apiece!
    swelltimes and GA Architect like this.
  8. swelltimes
    swelltimes SILVER Star
    865
    281
    Aug 9, 2012
    Western MA
    Lots of folks in the greater Boston area who could help you out with wrenching and advice as you work through tasks on your truck - just post up on the YankeeToys section!
  9. sproggy
    sproggy SILVER Star
    594
    128
    Nov 26, 2013
    What's this YankeeToys section? Where is it?
  10. swelltimes
    865
    281
    Aug 9, 2012
    Western MA
    Yankee Toys is a group of Toyota nuts in New England: MA/NH- Yankee Toys
    sproggy likes this.
  11. sproggy
    sproggy SILVER Star
    594
    128
    Nov 26, 2013
    I'll check it out. Thanks
