AutoCraft Aus
Araco Master
- Joined
- May 20, 2008
- Threads
- 15
- Messages
- 918
- Location
- Central Victoria, desert region.
- Website
- 4xoaus.com.au
The FJ is actually harder to design a coil for than the 80, due to the space, height, and dia available to fit the coil into.
We go 30mm higher on Slinky for them, like 80, 100 and 200, because we use a 40mm bump spacer to fit the extended length shock we run in there, compressed.
So we end up with a 3"" lift, instead of 2".
We are also using a straight rate coil in the FJ, rather than a dual rate, because we can get them to stay captive, and in 5 different rates, because we are actually using coils that are made for another application, that works.
Beats the time and effort, and $ that go into prototyping when you can.
The FJ flexes on the standard arms nicely too, roll steers less, maybe due to weight transfer with less overhang, and weight to an 80.
Unloaded ride height on 35's.
Us aussies generally like to carry more of a load, for remote travel than you guys, too.
