I know this has been covered before, but how far and at what speed is it safe to tow a FJ 40 with a towbar?
What is the reason for removing the driveshafts, assuming TC locked in neutral along with the transmission and hubs locked out? I'd be towing with a 2500 Suburban. I've only had to tow it once, when I broke a set of brand new points and then I towed it about 15 miles at no more that 45 mph, with a half ton Yukon. Stopping was the only issue.
Ed Long ???
Ed Long ???
DAGNOL, I'VE HEARD THE WORST THING YOU CAN DO TO A 40 WHILE FLAT TOWING, IS TO PUT THE T-CASE IN NEUTRAL. THE REASON IS THAT IN NEUTRAL YOU ARE ONLY SEPARATING THE TRANSMISSION FROM THE T-CASE, AND TO PUT IT IN NEUTRAL, YOU MUST PUT IT IN 4WD FIRST. WITH IT IN NEUTRAL THE ONLY THING TURNING IN THE T-CASE IS THE OUTPUT SHAFT, AND THEIR BEARINGS ARE NOT GETTING LUBRICATION.
