Is that an 80 arm on a 60 box? If so, could you tell me how much room there is between the castle nut and the frame. I'm looking for a pitman arm w/ less drop than my Marlin arm.
Thanks!
Nope sorry. That the oem 80 arm
So long as they are not a progressive wound coil spring, it is fairly easy to calculate the rate. A qwik google turned up this on-line calculator:
Pro Shock Coil Spring Rate Calculator
Another that might be a real bonus when fine tuning time comes along:
Sway-A-Way Calculators
If you want to see the math going on behind the scene:
Suspension Coil Spring Rate Design Equations Formulas Calculator
Others:
F-O-A OFF-ROAD Shock Absorbers
Coil Spring Rate Calculations by Wallace Racing
I believe that the air shocks mentioned are an air spring built into a monotube shock. Quite robust, but typically those are not good at carrying much weight or going very fast (temperature largely varies the spring rate). They are quite popular in light weight crawlers as they are simple and effective for that application.
What a friend has talked of doing, but has yet to actually do, is to put a single (large?) air spring at the center of the rear diff. It would carry the weight w/o having a huge effect on articulation. FFT
please excuse the noob question...
what's the advantages of doing this over just buying an 80 in the first place? is it just a $$ thing?
Reason enough? I just enjoy trying new things. Plus i like the 60 more than an 80. I have both but have always liked the 60 more. Cheers
