- Location
- United States
SOLD
It pains me to do this but I and listing my FJ62 with 242K miles. I bought this through a friend in Rogers AR about 2 years ago. PO blew a head gasket and it sat for 6-7 years. The motor was seized and needed some love. I bought a 220K engine from a fellow mudder that did the 5.3 swap that i wanted to do but no time to get it done at that time. $9700 Picture is before lift
The Good:
Original Paint (color sanded and buffed back to a nice shine)
No Rust on the body or frame
New Man-A-Fre Shackle reversal kit welded on
New OME front Springs
New HFS rear Springs
New MAF anti inversion rear shackles and grazable shackle pins
New Rancho 5000 Series Shocks
New O tiger Fuel injectors
New Toyota Dist Cap and Rotor
New NGK Plug Wires and g series plugs
New Valve cover gasket
New Fuel pump
New Fuel filter
New Radiator
New Water pump
Cold A/C(not ice cold needs a top off after 2 years)
New Battery
New Rear Brakes
New 31X10.50x15's on factory chromes wheels(a little flakey in the seams)
Fresh Tranny Flush
Fresh Oil Change
All power windows work but not all the switches(left rear will roll up and down with switch on the door but not the drivers door
Power Locks work
De-Smogged but left the air pump and lines in place. (Pulled EGR, removed and plugged Air injectors, umm cleaned out cats and reinstalled, Plugged all the vacuum lines. I have all the parts to put back back if you need/want them)
Fresh Tint last week on all windows
Newly installed Pioneer head unit with factory speakers
The Bad:
Both front and rear bumpers have been used and are not straight and one corner cap missing)
Minor dings on the body
A few minor scratches
Minor surface rust spot on bottom of rear window
Rear carpet is gone and needs a carpet kit or rubber mat
No spring on the gas cap door so you have to use key to open gas door
Slight miss of some sort but cannot for the life of me I can't run it down
Power antenna runs but mast is gone
The ugly:
Dash is cracked and needs a CruiserCorp cover $120(?) most likely will be done in the next 2-3 weeks
Front Axle seals need replaced
Transfer case pinion seal needs replaced(minor drops on the garage floor after sitting all week long. Does not sling fluid everywhere)
I think that covers it. Don't have to sell but I think I may have treed an FJ40 that is calling my name...
Devin
417.849.9OOO
The Good:
New Fuel pump
New Fuel filter
New Radiator
New Water pump
New Battery
New Rear Brakes
Fresh Tranny Flush
Fresh Oil Change
Power Locks work
The Bad:
The ugly:
Devin
417.849.9OOO
