i just did my shocks and steering stabilizer last week and the shocks took all of an hour.
I put some grease on the bushings - placed the bushing over the opening, (resting the steel ring part on a block of wood) then with a small piece of 2x4 and a mallet - one good whack on the block of wood pushes the bushing into the hole. worked perfectly and took just a few minutes to get them all pressed into place. just keep it all generally flat/level so that the pressure is applied evenly around the bushing and it doesn't try to slide out on you.
question i have about the steering stabilizer orientation:
1
or 2?
photo from the rig above (which is damn pretty by the way) shows it as #2.
my OEM stabilizer was installed as #1 - so I put my OME one the same as factory. I tried google image searches of FJ60/62 + OME and found it both ways on many installs.
any issues? should i swap mine to match yours @AdventureYeti
