I am using a BEP Marine VSR (voltage-sensing relay). Let me show you the comparison with another brand
BEP Marine 300A VSR
- 300A continuous, 1250A instantaneous rating
- marine-grade, sealed
- $135 on Ebay, + 2nd voltage gauge (~$30) or aus dual digital volt gauge (~$65) = up to $200
- on (combine batteries), auto (voltage sense mode), off (isolate batteries)
- auto mode- isolates Aux battery until Main reaches 13.7V
- control switch on unit housing with wiring/plug for remote switching (both on/auto/off)
cable/connectors
dual gauge showing Auto (voltage-sensing) mode readouts. top is Main, bottom is Aux
I've just been reading a thread on an Australian forum about the BEP gear - looks pretty robust and seems to be also quite inexpensive compared to the more recognised brands. The thread was mainly to do with a few guys that had had serious failure of winch solenoid packs that caused the winch to engage without any input or control by the remote switches, causing massive damage to bullbars and chassis rails as a result. In most cases there were no isolators between the winch and the battery, so the winch couldn't be stopped, so it just started ripping the bumper to bits.
I'm keen to hook one up now after reading it all, but I saw this setup and was wondering where the Dual Battery Readout came from? I saw the brand is made in Australia, but is it mounted in something (BEP Part?) or is it just a screen? The display is so well lit I can't see the background!!
Awesome rig by the way, I'm a details man too!!!
