FJ62 AC Low Pressure Switch Replacement Cost
Columbia, SC
... apparently went out and wasn't kicking on the compressor. Mechanic said it's 'up in the evaporator core' and that he had to bypass it because they couldn't find the part. $300 to bypass and refill with freon (it was 1/2lb short) Reasonable? Where can I find the switch (so i don't risk burning out the compressor)?
8 oz. of R-12 is about $20 retail ($30 for a 12 oz. can). 15 minutes to install it, and a few minutes to short the low pressure cut out switch. $300 seems a bit much, but if you're not DIY on stuff like this, you're a bit at their mercy. The compressor will only burn out if you run it while the A/C contains no refrigerant, so if your A/C starts blowing hot air suddenly, just turn off the A/C ASAP.
switch is behind the glove box...see step no. 2
