Holy smokes thats alot for a rebuild radiator!!! Looks like the home stretch!
Do you have any trips planned after the bugs are worked out?
Just saw this thread. Thanks for sharing. I can relate.
You'll be surprised at how quiet the 4BD2 is once you get rolling down the road. Even without the carpet you'll be able to carry on a conversation.
The heat coming up from the floorboards will be a killer though on long trips.
PS are you running a mechanical fan?
No - an electric fan. When we got the motor in it was positioned too low to line up with the radiator. I don't know why. I hope it isn't something that's going to be terminal. The shafts line up, so knock wood. But it necessitated an electric fan. The one I went with is the Derale 16116 H.O. extreme. It has good overall consumer ratings, 2024 cfm, waterproof, dustproof IP-68 certified motor and I bought an extra to take along in my repair kit in case of failure. It has 10 blades and is very thin. When you switch it on you can literally watch the engine temp gauge move down - amazing - something I would never have expected especially from a diesel. Mechanical would have been optimal, but it was what we had to do. The waterproof and the high cfm were the selling points.
Nice,
Im in the middle of a fan shroud build for my v8 as we speak. I'm hoping this time I got it right. My last attempt failed to fit, and Im pretty experienced with fiberglass. Its been fine without one, but Im hooking A/C up soon so I think i need a good shroud.
I always hear how e-fan just dont cut the mustard... hopefully yours will be cool.
Cheers
Sure. It will add lubricity to the diesel and the engine will idle quieter. A few ounces a tank full will accomplish that. You can easily run 40% VO in the winter and 30% VO in the winter in Florida w/o any ill effects.I'm considering running a percentage of vegetable oil mixed in with the diesel. I think I can get it a bit cheaper than diesel at Walmart or a restaurant supply store. Any thoughts, ideas, experience on this?
That is great news, looking forward to the photosA further note on FJ60 headlight buckets on Fj62 fenders. I had plans all set to modify the fenders to line up with the screw holes on the buckets but in between trips to the shop my guy installed them. He just used longer screws and they seem very solid - "installed" is the word. So that was the final step. You absolutely CAN swap the FJ60 front grille and lights onto an FJ62 front end. It was easy. From having read other posts/myths here and elsewhere, I was concerned at first. But compared with every other dang thing on this build? Cake walk.
My next detail will be headlight grilles from n FJ40 which I found on eBay in South America. I don't think it's a plug and play addition, but it should be fairly easy.
I'll post pics of the headlight buckets and screws as soon as I get over there and have a chance to. Likewise the headlight grilles.
If you're considering used or waste veggie, that's a whole other subject. Hold off, we'll have to talk. You have enough to do for a while before even thinking about getting into that.
That is great news, looking forward to the photosIf you could ask your guy what size screws he used, that would be swell.
Awesome progress, looks like you're in the final stretch!
I'm not negative on electrics. There are millions of vehicles using electric fans with no issues so I don't buy the reliability thing. A properly set up electric will have no problem cooling things down. In a diesel it's an advantage because during the winter months the fans rarely come on saving a load on the alternator. Offroad it's an advantage because they can be spinning at full force aiding in the cooling while going slow and they can be turned off during water crossings to save blade to fin contact. I have been happy with the flexibility of electrics in my rig.
