Hi All -
Another interesting issue with my 1987 FJ60.
The rig drives fine on flat land. Only when I drive up a hill in 4th gear does it begin to hesitate. Eventually it will just die out (kind of scary). After I get it (i.e. coast) onto flat land for awhile (and restarted), it begins to drive fine again. On the fuel side - the fuel pump, fuel filter, and gas cap are new and I rebuilt the carb (hopefully correctly). On the ignition side - the dizzy is rebuilt, the spark plugs, wires, and coil are new. Also, I have blown out the charcoal canister with compressed air thinking it might be a vapor lock.
I have always had trouble starting this FJ60 as compared to my FJ40. It can sometimes take 10 or 12 presses of the gas pedal to get it to start. Sometimes it starts just fine. When I got into it the other day, I pressed the gas pedal a couple times to start and heard a "gulp, gulp, gulp" sound from the gas tank. That, combined with problems on the gradual hill make me think it is a vapor lock or some air pressure problem.
Any other areas to investigate is greatly appreciated.
Thanks,
Stoshzack
Thanks,
Stoshzack
