FJ60 Trans Rebuild
Humboldt California
Hey guys. long time lurker. I need to rebuild my 4 speed in my 87 fj60. 4th gear is roaring.I'm capable of the work but i remember seeing a earlier post detailing the job with some homemade tools. I can't seem to find it now. any ideas or help? I have the FSM but not all the factory tools
From what I gather, you have two options due to a lack of parts available for the H41/42.
-swap to an H55F 5 speed
-swap in a lower mileage 4 speed.
On a budget the second will be far cheaper than a rebuild service, even if they parts were available.
I recommend the Terrain Tamer rebuilt kit from @orangefj45 Georg @ Valley Hybrids
Any needed hard parts and he will more than likely be able to help you with those too.
Drilling through a transmission rear output bearing
J
dsc00081-jpg.1047862
I've got two H42 (4spd) in the back yard you can have for free if you have a way of picking them up in So Cal (L.A.) area. Both were removed for 5 spd install.
Are you sure it's the transmission?
Usually they'll make noise in 1st-3rd and less noise in 4th.
If the combo is still in the cruiser then I would double check to see where the noise is coming from. A set of chassis-ears or a stethoscope would've a good way to determine the source of the noise.
Also keep in mind that to rebuild the transmission, you'll need to tear the Tcase apart.
I have all the parts and pieces as well as rebuild kits in stock.
Thanks for the plug Jason!!! @reevesci
And if you have any tech questions, I'll be happy to help.
I literally finished this combo 20 minutes ago.
Georg @ Valley Hybrids & Cruiser Brothers
View attachment 1374104 Are you sure it's the transmission?
More than welcome. Just want people to go to the right place for trans and t/c parts, IMO.... ;)
J
The PO of my 1987 paid almost $4,000 to have the transmission rebuilt back in the mid 1990's. Then.......less than one month later he paid the same shop to rebuild the t case for another $1,000. I would say the he got a bit ripped off! He saved all the receipts.
Mine gets progressively louder 1-3 and silent in 4th. Clearly it spends the most time in 3rd so that explains all the wear.
By the looks of that transmission, apparently Georg eats off his:)
I remember the first combo I ever bought from Georg. A new H55F and a rebuilt TC. Opened the crate and just stared at it. Almost made me cringe to take it out and install it. I remember getting a few smudged fingerprints on the TC and working frantically to clean them off. HA!!! pride of ownership of a masterpiece.....
J
